But you have the same air drag on a normal/organic bike as well!?
But maybe you're right, that someone who is slower and not often riding over 25km/h and so mostly using the motor support looses the feeling for riding without support and riding only rarely without motor then blaims the electric drive that it is that hard. I should try an experiment with my wife...
But this guy seemed to be quite fit (fitter than me) and with quite some experience on serveral bike types.
Again, maybe something is just not ok with his Vado SL.
You're riding a road e-bike with far lower air drag.
I can tell you I had far better average speed on the Creo than I could achieve on the Vado SL.
So you think I may feel the electric drive with motor off or over 25km/h as well more "chewing gum/rubber band" on the Vado SL as I would depend more on the motor/ride less time over 25?
Hmm, maybe. But as I said, I did already some tours with motor permanently off but quite some height meters. This means offroad/graveling a very low average speed of maybe 15km/h, far below a race bike tour in the flat and mostly below 25km/h. And it still felt good on the Creo compared to my "organic" bike.
I had a long enough ride on a Creo SL E5 on last Saturday to compare (57 km on roads with a single tough climb).
You look like a test pilot with that helmet and goggles. (I ridden with a guy that uses ski goggles to keep his eyes from drying out. It looks odd on a warm day but I works for him.)
@jodi2 I have a Creo and Vado SL and I think the Creo is faster due to the position on the bike. I have not done a technical comparison since I have not ridden the Vado SL since I got the Creo but I am riding the same types of routes between 30 to 50 miles. I think I ride the Creo in the OFF mode more than I did with the Vado SL and I can get a couple of mph higher speed on the flats. I cannot get either one close to the limiter on the flats with the motor power they have.
I couldn't wait for such a comment... :D
Agree.
I have a Vado SL 4.0, and this bike rides extremely well and fast...even with the motor off. I love the Vado, and have put roughly a 1,000 miles on it in 2 months. I don't feel any resistance at all....none. Hope this helps.
Allan there's no doubt for me, that a Creo is usually faster than a Vado SL, everything else would be very surprising.
My question was, is the Vado SL slower/more "chewing gum" without motor compared to similar "organic" trekking bike than the Creo is to a "organic" race or gravel bike. My opinion is "no", as I know no reason for this, but as I said, I don't know the Vado SL very well. On the contrary I see two reasons, that you may feel more difference between a Creo and similar organic bikes: The percentage of the extra weight for the electric drive is much higher on the Creo than on the Vado SL. Creo maybe +60% to a similar organic bike, Vado SL EQ with a good lock maybe +35% to a similar organic bike.
And the air drag of the Creo's frame is noticeable&measurable for fast race bikers. Not for me and not for gravel, but I've heard it from some fit roadies when they ride long&flat from 35-40km/h on.
I don't have a flat bar trekking bike other than the Vado SL 5.0 (or my Turbo S). My Creo is the Expert SL model with carbon wheels but I swapped out the carbon seatpost and saddle for a Kinect and steel rail saddle. I ride as much as possible in power OFF mode on both bikes usually at speeds of 12-14mph (20-23kmh) on the flats same as when I ride my traditional semi-custom gravel/touring steel bike. The Creo is my first carbon frame and even though it's heavier than my steel frame I don't believe it's noticeably slower in the OFF mode. I find the Vado SL is noticeably slower than my steel gravel/touring bike. This may be due to the poor fit of my Vado SL. Contrary to some comments if you are on the boundary between L and XL it does matter and you can't always correct it with parts. I have an XL Vado SL because at the time I purchased it, the dealer did not know when he would get Large frame and it seemed to sort of fit and only later did I regret not waiting for the correct size.
For me it was almost the oppoite. My Orbea Terra was a little bit too small for me as the step to the next size was very big. Also the dealer told my, ALL hist customers about my height ride this frame. And as the larger frame wasn't there at that time, I never tried the larger one.
My Creo was a little bit to big (so I had do put a 20mm shorter stem, 90mm instead of 110). But here I tried both sizes before and felt better on the bigger one.
After a few months I felt much better and more stable on the Creo than on the Terra, where a felt a little bit stuffed and which also has a slightly more aggresive/sportive/nervous geometry&steering. At the end I felt as good&fast on the Creo even with motor-off than on the Terra (which has no motor at all and 10-11 lbs less...).
So maybe your XL is not that bad/L would have been worse...
No the XL Vado SL is definitely too large for me even though using the height criteria I could go with either one. I assumed I could get it to work well enough by changing bars and stems without making look like a Frankenbike but it led to a hand problem that is only slowly going away. I think jump in sizes between L and XL is greater on the Vado SL than the Creo and I could tell the XL Creo was too large even though it was on sale and the large full price. I am huge fan of professional bike fits and it was fairly easy to get the Creo to the correct settings. Had I started with a large Vado SL I might not have any issues and I would have missed seeing I really needed a Creo. I see a lot of people uncomfortable riding because the bike is the wrong size or adjusted incorrectly. It's one thing to be tired after 100 miles vs too sore to continue after 60 miles.
It is interesting what you are saying Allan! I ride a Vado SL in size M, and I eventually fitted it to be comfortable for me. I demo rode a Vado SL in size L and was happy with that (only the top tube was a tad too high for me).
Now, I was sore after just 60- km on a Creo SL size M. Is it possible I would feel more comfortable on the size L Creo? (Unfortunately, my LBS has no Creo size L to just try it).
My "gravelized" Vado SL. See how low the handlebar is related to the saddle! It gave me a good fit for frame size M. Perhaps it should be a Large frame instead?
I rode many many years without a bike fit including my longest one day ride of 350 km in 2013. Towards the end of the long ride I could barely sit on the saddle. The next time I did that ride I split it into a 200 km and 150 km to make it "easier". It was worse because the second day I had a sore knee to go with the sore saddle. I finally went to see a sports physical therapist that also does bike fits. I was convinced my saddle was too low but as soon as I was on my bike riding the trainer she said it was almost 50 mm too high and the stem was too long. Mysteriously after a couple of bike fit sessions the sore hands, sore lower back and frequent saddle sores all went away. Prior to that I was convinced I knew how to set up a bike and even give recommendations on fit. Now I never give recommendations on fit but suggest that someone who does more than 20 or 30 km on the bike path is get a professional fit from either a bike shop that does real fits or a sports physical therapist. This is with your bike on a trainer for at least an hour where they watch you pedal, measure the angles and maybe replace some parts. Usually there is a follow up because you need a little riding time afterwards to settle into the new position. I've never done a Specialized Retül fit but maybe the shop you visit does them.
Yes, Specialized Warsaw offer Retül fit. I only don't know how it is done and whether you need a specific bike to do such a fit.
They put your bike on a trainer like a wahoo and they measure you as you ride. Their system uses sensors to measure and model your fit to make a little more techie. An experienced fitter should be able to get the same results with more basic tools and possibly a little lower cost. I think part of what their system is selling is consistency if you can't find your local best fitter. People assume it's only for elite athletes but it's not true. People will spend hundreds randomly trying new saddles and parts when a fit session can focus down to the right areas.
This is their fit program:
Thank you Allan for clarifying things.
The weak part here is "your bike". If they had Creo both size M and L, they could put either of the bikes (and me) on the trainer and could determine which size would be better for me. Unfortunely, they only have sizes M and XL in the store, so such a test could not be made.
P.S. The Retul app in the website tells me I need Creo size M, and it determined my saddle height very accurately. However, I have already ridden Creo size M with proper saddle height and came back from the demo ride disgusted and sore.
What is your size on the Vado SL? Creo and Vado Sl sizes are not exactly the same. I tried once for some miles a "L" Vado SL and it felt much to small while the Creo in L was accetable for me. But you can't really copy this to size M as Creo comes in six sizes, Vado SL only in four, so the "steps" between each size are different. But less big with the Creo from one size to the next.
My Vado SL is in size M.
I may be wrong but I really don't think ONE ride on a completely new bike with very different geometry shows much of anything. Posture, pressure points, saddle tilt and height were probably different than you are use to. So coming back with some aches and pains does not seem that unusual. But then again, the bike might have been perfect for you but the ROAD bike is just not for you.
There are so many damned variables in bike setups that solving them all in one or two rides - well, good luck to all of us.
I get some specific ache when I ride in an uncomfortable position: the pain manifests itself in one of shoulder muscles near to my neck. I was experiencing that ache when I was riding my Vado SL until I increased the reach. Again, riding my Vado in more upright position only affects my backside :) Creo was good for my ass but too much of my weight rested on the bars!
