Smart to dumb Battery replacement Help Please
Laine Golay
Hello, I recently had to replace my battery on my eKeys7 Super Hybrid that originally had a smart battery with connections for all of the 5 wires pictured below. My new battery only has the 2 large hot and ground wires that I connected. Can someone please tell me what the other 3 small wires are for (yellow, green, sm red). I assume that one of them if for the throttle because it doesn't work while the peddle assist does. Thank you .
I have no idea if the 3 wires you suspect have anything to do with the throttle. If I were faced with this "no throttle" issue I would check to see if there was power to one of the 3 throttle wires at the throttle. It's usually low voltage, something under 6v. You should have a positive, a negative, and a signal wire there.
