Schwin Merrdan SP?
vkray
I have a 26" Schwin Merridan Trike that is converted to a ebike! Well the front forks need to be replaced or repaired, the torque was to much even with torque arms! They are spread apart at. the axle wheel mount! Is there a replacement front fork heavy duty that i can buy to replace?
Or how do I repair ?
Thanks!
Contact John Bry He makes a torque arresting system that should hold you, I assume that the Meridan fork is a solid steel one?,I looked at an ad for a single speed Meridan, looks like an Aluminum fork( just test with a magnet) I am assuming quill stem, threaded .LBS should be able to fix you up with a steel one, shouldn't cost all that much.
John Bry is a merchant on EBAY, I got one of His sets, looks like the real deal.If I had seen your post I would have replied, I usually just peruse the new posts or the ones I am following, believe Me your dilemma has a solution.
