Rear tire flat
Beetlebomb
Had my first rear tire flat on my Rad Wagon.
I found out the hard way there is no need to remove the derailer or the the brake mechanism.
I did remove the clear plastic guard over the wheel though, just to make it easier to get the wheel back on. The trick is to tie the chain back from the wheel sprocket so when you put the wheel back all you need to do is untie it and slip it over the sprocket.
