Less than 10 miles on the bike. It squeals over about 3-4" section of the rear rotor. I cleaned them yesterday. Will try again tomorrow maybe with acetone.
Removed front and rear rotors
Soaked rotors 20 minutes in 90% alcohol, then wiped thoroughly with lint free cloth
Wiped pads down with 90%
Sanded rotors and pads with 320 grit and a block (have done and seen this done at shops before),
I took it for a spin to look at Christmas lights night (so great). And a quick 20 minute ride this morning. Squeal starts up when the power to the motor cuts off and I'm not applying the brake. If I stop pedaling, the sound lightly starts for 1-2 revs, then by the 3 time around, it's hitting that squeal, squeal, squeal pretty loud until I apply the brake either hard or light or start pedaling and the squeal stops immediately.
Any idea why the squeal starts and stops when the motor stops and starts respectively?
