Purchase information
Hi,anyone know of where I can purchase a three wheel e bike in or near Nova Scotia
ah!
Bad timing. Zen E-bikes will be located in Halifax but we aren’t operational yet due to COVID-19 challenges.
What kind of three wheel E-bikes were you looking at?
Is it for cargo or for someone who has physical disability?
Most 3 wheel bikes come with a limitation of balancing because of the lack of tilting and differential mechanism. But, there are some good ones.
If you have balance problems the best solution ( most expensive also ) is a trike with 2 tilting wheels on the front. Most Trikes with that design are for cargo however. Here are two different approaches for example. Cheap = https://www.voltbike.com/voltbike-trio.html OR pricey = https://www.butchersandbicycles.com/mk1e-touring The Voltbike will be tippy at speed but if you are slow and careful it will do the job on a budget. The second bike can fly around corners and carry your grandkids, your dog and your groceries (-:
Check with Watt Wagons. They are usually at the forefront of late. Not sure if they have something in the works but worth asking. You can call them or just use the site chat. Pretty responsive.
