Well, I only have a couple of hundred miles on the bike and my bike mechanic skills are less than rudimentary. Everything feels fine with it and I don't notice any pulling to the left or right when riding. I initially had some disc brake rubbing which I had adjusted at my LBS right after unpacking the bike. I'll put it up on a stand this weekend and see if I notice any wobble in the wheels. On the 1 day I commuted to work, there was an odd noise that surfaced and lasted for about 1 mile before it disappeared. I had just made a left turn and a noise started that sounded like the front disc brake area - same I had adjusted. After about a mile the noise was gone. It hasn't surfaced again. Hopefully I can get my Origen8 pedals soon and I'll ask my LBS to also give the rims a check. I need to spend a good amount of time with Youtube learning to check the rims and spokes.Over50,
How have you found the Alex MD40 rims
Do they feel solid enough and are they still running true
I commute by bike three days a week for about 55 min, so a bit less then six hours a week. If I use the helmet in blinking mode I just need to charge it once a week, if I put it in fix mode I need to charge it in the middle of the week. I bike through a natural park bike lane half of the way so I barely use the turn signals.
I have to say though that is a no brainer: they delivered the helmet with two cables, so I load at work; and with the phone app you can see at any moment how much battery you have.
My last two commutes I used Tour mode a lot more coming home. Recently, Chris at Propel was able to hook me up with the compact Bosch charger which I left at work. My prior commutes I did in one battery charge but I had to use Eco upwards of 80% of the time. Then after I experienced the 20mph headwind I described above on a return trip I figured I needed to charge at work. So these two commutes I only gave it an hour and fifteen minutes of extra juice in the afternoon and that gave me more than enough battery to do the return trip with probably 50/50 Eco and Tour. With a 10mph headwind using Tour is a lung and leg saver. Honestly that 16-18 mile return trip (dependent on exact route) is a piece of cake when I can rely on Tour mode for at least 1/2 of the trip. I probably hit Sport and Turbo just a couple of times for very short bursts where I needed to catch a green light.That was an interesting video. And you have a brave commute there...Are you in Tour mode whilst riding in the city? ...
Speaking of overheating, I was wondering if it could be heat related. Today's commute is an excellent example. Started in the morning to a chilly 34F. Bike was silent and joyous to ride at 5:30am on a chilly morning. About 9 miles in I would get some intermittent rubbing noise. It didn't persist. Then the ride home after a day's work. Outside temp was about 57F. Bike was silent for first 5 miles or so and then intermittent rubbing to metal on metal grinding. Sometimes the rubbing is barely perceptible and sometimes more perceptible. The metal on metal grinding noise is like nails on a chalk board. When that happens I can hit the brakes and it stops. I have visions of a road biker pulling along side and saying "so you have this nice belt drive bike, why is is making so much noise". Sometimes it happens after a turn. I come out of the turn and the metal grinding noise is evident. Some light taps on the brakes and it can sometimes disappear. I'm not enough of a mechanic to know what's going on or how to fix it. Or maybe I'm just too picky but I sure like the silence of the bike when it isn't making brake noises (silence apart from the motor I mean).I'm intrigued by your brake problems that were discussed in another thread. I have Magura MT4s (also hydraulic) and have encountered few problems in 1800 kilometers of riding. I'm going to swap out the front pads in 200 kilometers and the rear in 400. The front pads shudder and overheat slightly which has caused a light discoloration of the rotor at the connecting points, but I'm pretty sure that this will be fixed with kool-stop pads. ...
Sounds like grit and sand getting caught and passing between the pads and disc. If so then there is not much you can do aside from increasing the clearances between the twoSpeaking of overheating, I was wondering if it could be heat related. Today's commute is an excellent example. Started in the morning to a chilly 34F. Bike was silent and joyous to ride at 5:30am on a chilly morning. About 9 miles in I would get some intermittent rubbing noise. It didn't persist. Then the ride home after a day's work. Outside temp was about 57F. Bike was silent for first 5 miles or so and then intermittent rubbing to metal on metal grinding. Sometimes the rubbing is barely perceptible and sometimes more perceptible. The metal on metal grinding noise is like nails on a chalk board. When that happens I can hit the brakes and it stops. I have visions of a road biker pulling along side and saying "so you have this nice belt drive bike, why is is making so much noise". Sometimes it happens after a turn. I come out of the turn and the metal grinding noise is evident. Some light taps on the brakes and it can sometimes disappear. I'm not enough of a mechanic to know what's going on or how to fix it. Or maybe I'm just too picky but I sure like the silence of the bike when it isn't making brake noises (silence apart from the motor I mean).
On a prior occasion, I adjusted the back brake myself and it was the first and only time that I was able to do so successfully. I rode about 20 miles with beautiful silence before it started rubbing again. That 20 miles was 16 to work on a chilly morning (total silence) and then 4 miles into the commute home in 60 degree evening temps the noise started.
It could be contaminated pads. Disc brakes are sensitive to oil and other contaminants. A trick we do in the shop on occasion is wipe the rotor with alcohol to clean them and take some sand paper to the pads. This can remove any surface imperfections that could be causing the noise. I would also make sure that your axle nuts are tight. They can loosen over time causing slight shifts in the wheel and consequentially changing the clearance in the brake caliper. Give us a shout if we can help or maybe we can just reimburse you if you bring it to a shop. I feel bad that you're having this trouble.
Thanks! Let me know if I can assist in anyway. I really dig the Roadster as well. It's quite stylish. A customer just picked up a black one yesterday and it looks really sharp although I really dig the blue as well.
