Newbie m620
Gr3
When I first tried this bike I pushed on throttle pulled a wheely almost run into building. I ordered the programing cable. So I'm definitely going to change some settings. If you lower the current settings does the lower the power and watts of motor? I'm going to try some of the smooth settings. Thanks for any help.
See this thread. It will help a lot.
Would a 250W mid drive be worthwhile for me - a 'reasonably' fit cyclist?​
Yes there are a few ways to lower the power of the motor.
Lowering the Global Current at the top of page 1 will lower overall power to the motor
On the same page you can also lower current % at each PAS.
On page 2 lowering the Start Current will lower the power at PAS start. On page 3 you have the same setting for the throttle.
Also on page 2 raising the Slow Start Mode to 5 reduces the acceleration rate
There's many other settings that will help refine the motor so start reading various threads here and on the web for a better overall understanding.
On the bold is where I would start.
This might be a good read as well::
