I will gladly share what I know, but please understand that it might not be totally accurate as I am not associated with them in any way except as a satisfied customer. Magnum is an ebike manufacturer that has been around for about 5 years and I believe it is headquartered in Israel. They have sold a lot of bikes in Israel and in Europe, and currently have two Magnum models: Ui5 and and Mi5. The five in the model name refers to that they are the fifth generation version of these particular models.
Magnum is also the distributor in the USA for Leisger bikes which is a German company. They do not design/build those bikes but as of very recently, they do sell and service them here. They are just getting started with both the Magnum and Leisger brands in the US, which is why the dealer network is still very limited, although it sounds like they have plans to expand their network. You might contact them and just ask if there are going to be any dealers closer to you.
A lot of the ebikes out there are designed and "manufactured" by companies in Europe, the US or elsewhere, but the actual bikes are built and/or assembled in China, and that appears to be the case with Magnum ebikes. So it is kind of confusing as several even well known brands are actually built in China....but according to the specifications and quality requirements of designers in the west. The ebikes that are actually being sold by companies located in China do not in general seem to be up to par yet with their designs and specifications, and then you are at the mercy of customer service that is sometimes also based in China.
Based on my own experience, I would only recommend that someone buy a bike online directly from Magnum if you are fairly handy and familiar with working on bikes, or if you have a local bike shop that is open-minded and will assemble and work on the bike for you. I have no way of knowing if my experience is at all typical of the Magnum brand, but there were a handful of problems that showed up for us in the two bikes we purchased, and so I have had to do some repairs myself. It is pretty basic stuff such as swapping out the rear motor/wheel on one bike which involved moving the brake disc, freewheel, and tire from one wheel to another. The other problem was a motor controller issue and in that case Magnum sent us an entire replacement bike. This meant I had to assemble a third bike out of the shipping crate and make sure everything was OK on that one, plus take apart the original bike and put it back in the crate. The other challenge for me at first was attaching the handlebars and stem to the bike as I was not familiar with the integrated style of stem and how it attaches to the headtube of the fork. As a result, in attaching the handlebars of the first bike we received the headset bearings fell out and I lost some bearings. It still worked fine, but Magnum sent us a new set of bearings that I then more carefully installed. If you install the handlebars immediately, before even fully unwrapping the bike, it should not be a problem. Unfortunately, there is not a manual or set of instructions that come with the bike, so you are pretty much left to your own devices (although Magnum says they are working on a manual), and there is the video found further up in this thread that now shows how to install the handlebars.
Other than the attachment of the handlebars, there is actually very little other assembly required. I think it was just a matter of putting on the pedals, pumping up the tires, and installing the optional rear rack. The brakes were pretty squeaky until I learned how to adjust them according to this video:
One other tricky thing which must be common on ebikes is that it is difficult to get to one of the adjustment screws for the rear disc brakes because of the hub motor. You could of course just remove the rear wheel and adjust the brake and then remount the rear wheel to see if you got the adjustment right, which might take a few tries. But given how it is a bit challenging to remove and remount the rear wheel of an ebike with a hub motor, I instead used a hacksaw to cut down the shorter end of an allen wrench so that it would just fit between the hub motor and the brakes (it has to be very short). It worked for the slight amount of adjustment that was necessary.
With all of the problems that showed up, Magnum was incredibly helpful and worked with us until they were fully resolved. The replacement bicycle showed up within a few days of when I told them about the faulty controller, and the replacement wheel/motor and other parts showed up promptly also. I think the bikes are a good value for the money, but of course the components are low to mid grade at this price, which in the long run is probably another good reason to either know how to work on the bike yourself, or have a good relationship with a bike shop. We are having a lot of fun riding our bikes, and these bikes were affordable enough that we could buy two of them so that my wife and I can ride together.
I hope this helps and please let me know if there are any other questions.
