Perhaps you can leave the brake calliper off the mount and see if the issue occurs? That way you can identify if it is brake related or not.Yeah it still seems to be having the same issue between 20-30 it feels like a vibration but when I lean for a corner it gets stronger almost like a grinding feeling but with no sound but there is a resistance feeling slowing me down but the hub has good engagement for acceleration
If you need LBS support you should definitely buy from the LBS. But that doesn't necessarily mean better support than buying direct from manufacturer.This is what exactly happens when a LBS (like Biktrix) goes nationwide on mail order.
That gets them more sales volume, but unable to provide value added support to those that aren't local.
Question is: would you recommend a non-local to purchase from them?
I did originally try that I even changed the pads and re bled the brakesPerhaps you can leave the brake calliper off the mount and see if the issue occurs? That way you can identify if it is brake related or not.
It's either that or something didn't get installed properly on the hub.. may be the cassette isn't installed properly on the freehub body?I did originally try that I even changed the pads and re bled the brakes
Biktrix is basically two partnered LBS shops with their own brand.But that doesn't necessarily mean better support than buying direct from manufacturer.
i have taken the cassette of and tried to tighten it again i even tried another cassette on itIt's either that or something didn't get installed properly on the hub.. may be the cassette isn't installed properly on the freehub body?
I know... Have you tried removing the tire and rotating it 35° and then remounting it while hopping on one foot and humming God Save the Queen?It's either that or something didn't get installed properly on the hub.. may be the cassette isn't installed properly on the freehub body?
Except for the same 4 cheerleaders
If the panties fitOh? You peaking up skirts again?![]()
I did originally look for some hubs but wasn't having any luck finding a 197mm hubLate to the party here but I’ll take a shot. If you had the original hub repaired internally and it still isnt right they didnt correctly fix it. This bike comes with lower end hubs so throw it away and buy a brand new hub and build up another wheel and then your riding again. My friend that blew his up last year has not had any issues since we replaced and built up the new wheel. Biktrix bikes are a price point bike IMO. They use lower quality parts to make it affordable. The hubs are Quanta I think. Amazon $60 for a pair. DT Swiss, White Ind. $$ but never fail. I like Hope hubs $100 for a front, $200 for the rear. Any bike you purchase out of your area you better be prepared to fix things yourself or wait 6 months for ...
Sending you a new replacement rear wheel. Saw your email today. My team will be in touchI
I have seen a couple now but just worried if the extra torque will chew them up I have the bafang ultra and the hope hub I saw think only had 4-8 pawls but I assume better material on it
the stock biktrix one has like 20-24 didnt actually count but there was more than i have ever seen
On top of the investment already
Sending you a new replacement rear wheel. Saw your email today. My team will be in touch![]()
thank you, gonna be a much better summer not worrying about that anymoreSending you a new replacement rear wheel. Saw your email today. My team will be in touch![]()
