Hi does anybody know the tension values for front and rear weels on the Moscow using a tensiometer
J jeffkidney Member Dec 20, 2020 #1 Hi does anybody know the tension values for front and rear weels on the Moscow using a tensiometer
stanmiller Active Member Jan 13, 2021 #3 jeffkidney said: Hi does anybody know the tension values for front and rear weels on the Moscow using a tensiometer Click to expand... As I recall the Moscow has 13g or 2.3 mm spokes. According to this chart for Park Tool's meter, the tension should be between 22 and 32. https://www.parktool.com/assets/doc/product/TM-1_conv-table.pdf Also, the cassette side of the rear wheel and disc side of the front will have slightly higher tension than the other side. Last edited: Jan 13, 2021
J jeffkidney Member Jan 13, 2021 #4 stanmiller said: As I recall the Moscow has 13g or 2.3 mm spokes. According to this chart for Park Tool's meter, the tension should be between 22 and 32. https://www.parktool.com/assets/doc/product/TM-1_conv-table.pdf Also, the cassette side of the rear wheel and disc side of the front will have slightly higher tension than the other side. Click to expand... Thanks for the information I found around 28 seems to do the trick week runs true no rub on the discs either
