Mississauga Calling....Volt or Teo bike Help me make the right choice
I am hoping I will receive it Friday and then put it together. That may take some time as this will be first time I am doing this
@YYZ2017
No rush, first make sure to enjoy it.
Never done an ebike but I did take my Motorino electric scooter apart and managed to put it back together, if you need a hand...
It was too cold as it quickly went up to 30 and I wasn't prepared for the cold wind. Going shopping today
Thanks guys much appreciated. I actually already have a balaclava that I bought for riding motorcycle but never wore it because my helmet was too tight lol.
I went out for a quick ride (only 5km) had my tires pumped to 20 psi and there was quite a bit of rattling. I found the rear kick stand screw 80% out when I got home, tightened it., will try again later. What is surprising is that after 5km of riding my charger has been going for over 1 hr charging...
How long is it suppose to take to full charge if battery was say only 20% left?
@YYZ2017 you can always put a dab of this on the tread
http://www.canadiantire.ca/en/pdp/loctite-threadlocker-blue-242-adhesive-0670036p.html#srp
Thanks, However, this is in the description:
  • Use on metal fasteners 1/4' (6 mm) to 3/4' (19 mm) in diameter such as bolts on small engines, swing sets and furniture
I am assuming because of the torque required to "break" the loctite bond, anything less than 1/4' could cause the bolt to break?
I am not sure if it is safe to use for this application as the bolt could possibly be on the thinner side?
maybe there is a lighter "loctite"?
Benoit mentioned that the kickstand is, surprisingly, the one part that tends to loosen up. After tightening hard, did not budge in weeks. At 20%, expect a good 6 hours I guess. I never got that low so I can't confirm for sure.
6 hours? I guess that makes sense maybe even more @ 2A... maybe even more.
wow looks like I should shop for a faster charger....
Oh I remembered :) However my back has been killing me past few days not sure why... hopefully I'll be out and about this weekend.
Sorry to hear about your back, if you like I can recommend someone that fixed my back.
