Magnum UI6 instructions attached to change controller settings
joearena99
Couldn't find this online anywhere, so I called Magnum. They very nicely emailed me the following instructions. Enjoy
Cameron Gibbons <[email protected]>
Hi Joe,
Here is the step-by-step instructions to gain access to your displays settings.
  1. Hold + and - for about 5 seconds
  2. You will see the screen change to 8888
  3. Using + or - to change numbers and set to toggle
  4. Change the code to 8088 “if that doesn't work use 8306 or 8108”
  5. The first screen is P. Pedal assist top speed
  6. The second screen is throttle top speed.
  7. The third screen is tire size
  8. The fourth screen is odometer
  9. The fifth screen is battery size
  10. The sixth screen is power level
  11. Hold set to exit back to the home screen
