Magnum Metro+ Electric Bike 48v, 500w, Speed Pedelec, bodyfloat, Air Zound
Trail Cruiser
Ebay sale: https://www.ebay.com/itm/265331690575
Speed Pedelec, Bodyfloat, Air Zound, with Throttle
1,218 miles on the odometer
Bodyfloat (Kinekt) suspension post ($249 value)
Delta Air Zound
Extended front mud flap that keeps your feet dry when riding on wet roads, It also
keeps other vital parts from dirt and water splash such as the chain, chain ring, and
most importantly, the the electronic controller module (at the bottom part of the downtube).
Cadence meter is made up of a regular speedometer that is recalibrated. For example, if the
display says 7.6 kph it means the cadence is 76 pedal RPM (easy to get used to).
Local pickup only (Yonkers NY) or will deliver to within 50 miles of zip code 10704.
Video below is the original configuration.
Delta Air Zound
