I was confused if it did or not when looking at the LMT'D. Some reviews said it doesn't and some said it did but no one said they knew for sure what it came with.
R1U just said all LMT'S come with torque sensor but they didn't say when they started doing that.
So sorry if I sounded like I know what I'm talking about. UTube are sometimes hard to separate the truth from fiction. I'm the first to admit I'm a noob to Ebikes but I'm learning something every time I touch it.
It's good you're alert for discrepancies and some confusion is understandable.
The Lm'td is a great bike to learn on. I did. It's relatively simple. The tools required are paid for in a year or two - doing your own work - and knowledge is priceless power.
I don't know
what I want if I don't
understand it.
It's why I'm prepared to wreck stuff. To
not repeat mistakes we have to err. Tear down, rebuild better.
Stay determined. I salute your enthusiasm.
We can't accurately say why R1U discontinued the Torque Sensors.
Most work well. According to my conversations with R1U staff (thanks Olympia - and all the rest. You're an awesome crew !!!), the biggest danger's improper removal and/ or installation - without following R1U's specific instructions to a tee.
The sensor wires thread out of the lower battery compartment, down through a small hole, into the bottom bracket and the sensor.
If you rotate the sensor
at all, you'll shear the wires (snip) and the TS is likely ruined.
I had
a wiring issue causing
intermittent TS symptoms. It was actually
the Display cable's plug had a bad contact.
Drove me nuts.
Contacted R1U insisting it was the TS and they gave me a nice education (stressing the dangers of disassembly).
Took it all apart and put back together. Wires were fine.
Any number of things can
appear to be a defective TS - but that are not the issue.
There was one guy, three TS's in a row, installed by an LBS and all three failed. A well known member here (ripped the words outta of my craw) told him 'change LBS's'. What are the odds? Getting close to the definition of insanity. Perhaps the initial problem had nothing to do with the TS.
At any rate, trade; supply; defect problems, we don't know, but R1U discontinued the TS.
Apparently, R1U resolved the issue and began installing TS's again - liquidated the Cadence Sensor bikes on hand and I don't believe any more are being made.
As a rule, I observe people who ride
distance prefer cadence, and City -
stop and go - riders, torque sensors.
CS are more for strong bicyclist types, set a pace and hold it like a machine. Years of riding, switching to an eBike, naturally they have the stamina and muscle developed. TS has has a more universal appeal, esp. for new riders. Now, many higher end bikes come with both.
It's certainly not manufacturers pumping TS as a feature driving the popularity. They're the more complex and expensive of the two assist systems. It's the convenience of relatively 'right now power' vs. 'in a quarter turn power'.
A huge influx of new riders. Here and there last year, they're everywhere now. They'll set the standard.
Ride on
FnF
