Hello. Thanks for the reply. I was guessing/hoping it would work, but just to reiterate-- My bike is this one:
https://www.alibaba.com/product-det...827.html?spm=a2700.8443308.0.0.40113e5f8SPNjf
When I contacted Cirrus Cycles, I was asked if it was for an Elby, which I said it wasn't. When I showed them the link above, they replied:
"Oh dear!
We have a problem then as the post on that bike does not taper in the same way that the post on an Elby does and we have not found a commercially available shim to 33.9 from any source.
At this time we have no solution to this problem.
Sorry."
I then replied and asked for any BodyFloat 2.1 420mm regardless of the diameter that will fit a 33.9mm, and they replied:
"We have not yet found a shim that goes to 33.9 mm so the only option I see is to aquire a seatpost from an Elby bike to which we can bond our front link and then attach the rest of our unit. We have done several of these and they work well.
Let me know if you find that plan attractive."
I just wanted to make that clear before pulling the trigger, as the BodyFloat 2.1 is quite pricey; though if I get it through Amazon, their return policy is quite nice if it doesn't fit.
Lastly, is there a performance between the 2.1 and 3.1? Other than weight, length, carbon vs aluminum, is there a reason to get the 3.1 over the 2.1?
