Isn'tyours a gear drive motor? If yes, no regen. Regen is useful for braking. Most use it for braking not charging.Grin Technology has a video about regen.
All I've seen do, but twist are a PIA when moving a bike around with power on. Inadvertent tis will send the bike flying out of hand control. IMEYou saying the twist throttles don't spring to off if they are released?
I have seen this four times. Disasters each. As the bike flies up the twist increases. It is all too fast for conscious modulation, in the moment you can't let go when it is flying. Naturally one wants to hold control as it smashes upright through a glass door. All it takes is one second. These electric motors have immediate torque. The idle is silent, still, and awaiting only a guiding slight twist to fly.will send the bike flying out of hand
If you are dedicated to letting the motor do all of the work, do that. I ride unpowered as much as I can, and the clutch allows me to do that without drag. When the wind in my face gets over 18 kph, on goes the motor. I don't like riding 6 hours at 7 kph & 140 bpm. I'm age 72 and my heart "has nothing wrong with it" the cardiologist said. .Also, AFAIK, the clutch in it can be welded and if the controller supports it, I could get regeneration braking. A second torque arm would be better in that case.
How to you hold the twist - with all your hand wrapped around it? If so, yeah, poor control with that. Learn how to hold the it right so you have it right. For example this videoAll I've seen do, but twist are a PIA when moving a bike around with power on. Inadvertent tis will send the bike flying out of hand control. IME
After you weld the clutch, when the rain takes out your throttle, enjoy the $80 ride in a tow truck. I pedal my bike to repair base unpowered myself. One time was 24 miles. Riding a DD motor unpowered was a real nuisance. Put it in the garage. Dragging a geared motor rotor at 5X the wheel rotation with your feet would be a real PIT*.
My twist throttles have sprung to off position themselves. 3 of them.
I make torque arms out of a piece of bed frame rail. Cut flat 1"x4", drill two 5/16" holes at right offset for motor axle, connect the dots with nicholson triangle file. Drill 11/32" holes for #10 screws for the 1" sheet metal fork clamp. Use #10 elastic stop nuts to prevent loosening. Alternate for international, 5 mm screws & nuts. Do not use hose worm clamps, they will stretch under torque.
Must not be very windy in Oz. Dragging a solar panel on a trailer would be nearly impossible here into a 50 kph headwind. When 100w 48v solar panels can be rolled into a 2" diameter tube I might think about carrying one in a pannier. I use panniers mounted behind my legs to cut the air drag of carrying cargo.
those of us that worked support for nearly a decade know full well motorcycle throttles an eBike throttles have little in common. Who moves a MC while the motor is running and gearing is engaged? We’ve seen dozens of reports of dumped eBikes and twist throttles.How to you hold the twist - with all your hand wrapped around it? If so, yeah, poor control with that. Learn how to hold the it right so you have it right. For example this videothe 'dragger' method explains how I ride. I'm always covering the brake.
dumped eBikes
I view Grin promotion of elimination of one-way-clutch in geared hub motors one of the stupidest ideas of the last decade. Freewheeling using the clutch in the rear axle is fine for downhill runs. 50% of the hills I cross are up. I pedal uphill using muscle power most of the time if there is not a gross headwind. Maybe you have ski lifts to carry you up every hill you ride? The wife hauls you to the top of the hill in the SUV?I'd encourage you to watch the Grin Technologies video on regen. Watch the bit about virtual freewheeling.
It's a shame you count every innovation that doesn't fit your ride style as stupid. BTW it's not a "promotion", it's an innovation scores of buyers find as useful.I view Grin promotion of elimination of one-way-clutch in geared hub motors one of the stupidest ideas of the last decade
This!but have learned to turn off the controller before dismounting and to turn on the controller only once your are in position to start rolling.
