If you have a garage then consider a bicycle hoist instead. Get one rated for 100lbs and securely attach in to your rafters with a 2x4. I have been using this setup for years to work on my bikes and recumbent and also easy storage for winter. They can be found on Amazon and many other sources for $20 OR LESS. Avoid Harbor freight models as it is only rated for 44lbs. You can use the lift to raise your bike to any height you choose. As a safety precaution (not really necessary) I zip tie the hooks to the bike to avoid the hook slipping off (has never happened - lol).
