DETAILED REPORT ON THE STATUS OF SEVEN SPECIALIZED BATTERIES
U1-600 Batteries (nominal capacity of 604 Wh)
- The Gray battery. Manufactured in 2017, activated on Nov 1st, 2019.
Health: 92%. Recharges: 107. Actual capacity: 547 Wh.
- The Black battery. Purchased in April 2020.
Health: 94%. Recharges: 107. Actual capacity: 501 Wh.
- The Blue battery. Purchased in October 2021.
Health: 100%. Recharges: 12. Actual capacity: 533 Wh.
The first battery was used exclusively for the first months of my Vado 5.0 ownership. The number of recharges might be wrong as the e-bike was equipped with the obsolete BLOKS system by May 2020, so nothing is certain. Since the purchase of the first spare battery, I have rotated them to get the Gray and Black batteries at the same number of recharges.
What is very depressing is the fact that none of these batteries was ever even close to the nominal 604 Wh, even the new battery bought in 2021. With these three batteries, my installed battery capacity is 1581 Wh.
Note: The Vado 5.0 odometer reads 13,333 km.
SL Main Battery (nominal capacity of 320 Wh)
Originally, the battery indeed was at 320 Wh full capacity.
Health: 94%. Recharges: 73. Actual capacity: 302 Wh.
SL Range Extenders (nominal capacity 160 Wh)
- Battery labelled "chemical": Health: 99%. Recharges: 32. Actual capacity: 158 Wh.
- Battery labelled "engineer": Health: 99%. Recharges: 28. Actual capacity: 158 Wh.
- Battery labelled "hero": Health: 98%. Recharges: 58. Actual capacity: 157 Wh.
With my Vado SL, I set the "Discharge the Range Extender first" option for everyday rides, hoping to equalize the number of recharges for all SL batteries. On long rides, I discharge the main battery and the Range Extender in parallel.
The Vado SL odometer reads 6,524 km.
My Batteries' Usage
If I followed the 80-20% charge/discharge plan, I would ride nowhere. My batteries are regularly charged to 100% and discharged even down to 5% when necessary if the ride is to be a long one. I need significant assistance to help my ailing legs, and think the life is too short to waste it for meticulously maintaining the batteries
P.S. All data for Specialized batteries have been obtained by BLEvo, an independent app from Paolo Diozzo. The latest Mastermind e-bikes killed BLEvo, and I think I know why... Because Specialized Mission Control will never tell you the truth about your battery status.
