BBassett
Without trying to sound like a Bosch fanboy or anything, their system with 2 batteries in use whereby the motor uses 5% (different if capacity is not the same) from one battery and then switches to the other and vice versa allows the battery chemistries to settle. This is even more beneficial when high loads are drawn causing them to heat up and even more beneficial if you're going to charge them straight after use.
Yeah, high draw isn't a problem for me... or most people I believe that use their gears as much as the motor. Ride it like a cute little baby motorcycle and you get lots of heat. But I guess a system like that is almost necessary when you are using little batteries placed around the frame where they will fit. What's next 5 or 6 all strung together around the bike with some proprietary connector so you have to buy from them?
