Help please
L herber r
I have a Chinese branded cheap speed controller runs 80 amps 2000 Watts at 60 volts the problem however is that is has a factory soft start implemented in the speed controller there are no LCD pins for heads-up displays I was wondering if there's a way to bypass remove completely or get around the soft start because for my build I need all the power instantaneously the slow ramp-up provides jerkiness on a throttle only type scenario any ideas for his life would be greatly appreciated PS I have already soldered the shunts together so they are one if I have to crack it open and remove some things from the motherboard I do not have a problem with that
