Twogoldfish
- USA
My son has a Jetson bolt that he rides to school. It won’t charge and I am trying to determine the cause. He rode it every day last week and it charged fine until last night. The light on the charger stays green at all times and I don’t see the normal voltage change on the bike when I plug the charger in.
Here are some tests I have run:
Charger: I don’t see voltage coming out of the charger. I’m not sure if this is because my meter isn’t sensitive enough or if the charger needs to see voltage from the battery before it will start charging.
Battery: The battery has terminals for power and the charging port. I am reading 32.4 volts for the main power, but there is no voltage coming from the charging port wires. Based on research I have done, I think they should have power.
I’m not sure how many cycles the battery has had. He has been riding it to school for almost a year now. Until today, it has worked well. So maybe 25 cycles..?
Hoping to get some advice so I don’t order an unnecessary charger, battery, etc.
