Help! Bought a used ebike with battery/BMS issues..
WheatyPop
Recently I bought a used Velowave Ranger ebike, and I have spent quite a bit of time fixing it up. I finally had it up and running, but I discovered a pretty severe issue with the battery.
The battery works fine during pedal assist 1 and 2, but if I go any higher, the battery will shut off and not turn back on. Full throttle has the same effect. After I plug the battery into the wall, it will turn on again. This seems to be a problem with a weak or unbalanced battery pack - I just don't know how to fix it.
I'm currently trying a long top-balancing session to balance the cells in the battery. I'm not much of a tech guy so any help or assistance is appreciated. thank you
That happened to me because a bike had sat too many weeks or months. I plugged a watt meter into the wall, a timer into the watt meter, and the charger into the timer. (Watt meters and timers can be under $10 these days.) The watt meter gave me an idea of how much charging was going on at the moment. The timer was to be sure it didn't continue to charge when I was away. I'd charge it in increments of an hour or two. It worked out well.
Just to add to what @spokewrench said, please be careful if you do this to try to revive and balance the cells. Do this in a place that’s away from combustible materials. If a battery has a weak cell, there can be several reasons for that, some of which may not be repairable by recharging.
If a lot of heat is being generated with your charger on you might want to be circumspect. Do you know anything about the history of the bike? Good luck!
