I am wanting to monitor power usage on my longer trips as I know I may have an issue going back on a depleted battery. I drive an electric car and have an instantaneous measure of my power consumption. I would like the same on the bike. I know I have 5 bars as an indicator but to choose an optimal gear/power assist combo would be great. If my hearing was more acute, the drive noise from the 750w motor would tell me I guess. To use the Hall effect it is only needed to run a power cable thru the yoke and supply a low voltage battery to the gauge. My PIM has two heavy quick disconnect cables to the motor with easy access. No idea which is going to the motor and which is coming from the motor/regeneration. Since power is unlikely to be flowing both ways at once, can I just run both thru the yolk? Any other ideas? This is a small investment in the $20 range. Thanks
