Haibike yamaha display error
Butty09
Hi, anyone have idea what issue might be with my Yamaha display on my haibike sduro?
It got damaged recently and I had to fit a new wiring loom and display but when powered up it shows ‘Er 15’ which flashes on and off. I am unable to clear it.
any ideas?
thanks
Ian.
Attached is the Yamaha PW service manual. On page 2-39 it says in reference to Er 15, "Replace the display unit assembly." Since you've already done that, perhaps it is incorrectly installed. Have you tried contacting your dealer or the Haibike distributor?
  • Yamaha PW Service Manual.pdf
Thanks. That is a different manual to the I received?? This has more detail but still says same about error 15 hence why I changed display.
it’s looking like the display I have got new is for 2015 models only and that is the issue?
I am getting a refund and sourcing a compatible spare. Unfortunately when purchased it did not state 2015 models only!!
thanks guys and I’ll try new display when get one
Within the PW, the year of manufacture is the one that determines the type of control even if it is similar or aesthetically equal, if you need a control or a screen you must know if it is 2015 or 2016 + because even being the same they do not work, there are 2 specific versions for the 2015 and for 2016 + controls and screen.
At some point I had a 2016 PW bike and a 2017 - the displays were interchangeable for them. Never had a 2015
