Calahonda52
First post here.
Looking at my first e-bike, have rented them across 4 continents so understand the basics
Am 6'1, 67, and have lower back disc issues and my C3,4 & 5 are not the most flexible.
Have been taking several brands of bikes for test spins.
One bike that I particularly like, the Haibike 120Nm fly-on, does not offer the option of raising the handle bars by fitting a longer "head-stem" if thats the correct terminology.
The problem with the bike geometry on the one I tried is that with the saddle at the correct height for pedalling, I need the h/bars to be about 4" higher to be able to see ahead comfortably.
this is a size 48, what ever that means, and the supplier has penned the following when I asked about getting a 50 or 52.
Hi ,
Using stem risers is not recommended on this bike.
Currently, there are no high rise bars available for this bike either (the handlebars have specific routing for contol cables)
If you are able to stand over a larger sized 50cm bike, the head tube is bigger giving a greater stack height.
It's worth bearing in mind that a larger bike will have a longer reach too.
Best advice is to visit a dealer to discuss sizing and geometry.
I asked about the reach:
Reach relates to how long the bike is.
If the reach is too short for you, the result can be excessive pressure on your hands, and possible knee contact with the handlebars.
If the reach is too long, and your back is not very flexible, or if you have low core strength, your body will compensate by moving your shoulders forward so you can reach the handlebars. This can result in neck, shoulder and back pain.
As mentioned previously, the best advice is to visit a store and try the bikes, as this all depends on your body geometry too.
Would welcome any insights on bike verus human geometry.
Thank you.
Hi ,
Thank you.
