We have an Aventon Pace 500 with Tektro HD-E350 brakes. We have close to 1100 km on the bike. The bike started to develop a noise that sounds just like the freewheel when you coast without peddling, but a bit louder, when I use the front brake after it past the 1000 km mark. I thought the brake pad may be worn, so ordered some replacement pads. When I took the old pads off, it looks like it has plenty of pads left, really not much thinner than the replacement pads. I cleaned the pads and the rotor, and put everything back together with the original pads. The noise is still the same.
What may be the problem? I checked the front axel, the bolts on the brake caliper, etc., everything looks to be snug and tight. Any ideas what I should check next?
Thanks,
Thanks,
