GypsyTreker
I finally installed the suspension forks I purchased in late November on my Ecotric Fattie 26". The install was easy beans, you simply need to remove the side mount adapter on the calipers since the new forks are a front mount. I also changed the stem mount for more adjustability. So first things first. You feel the added weight and the changed geometry. At first I thought I might have tightened it down too much but it's simply the way the forks sit further forward. The steering is heavy but something I will easily get use to. I also lowered the bar height....very different feel. I will need to experiment adjusting the suspension a bit. They actually work fine on the down stroke and totally remove the jolting ride the ridged forks provided. Without any air the forks top out, mostly an annoying click rather than a "thunk"....easy fix. I will give an update once I really put some miles on them. My wife and I just spent 5 days riding off-road and camping and my shoulders like to feel as if they are dislocated. Really glad I didn't send back these Suspension forks ($148 on Amazon...numerous branding/same fork I am pretty sure)
Anyway nice upgrade to a $ 750 fattie.
