Gee_Whiz
Because I couldn't find a similar thread and I think it would help future Frey buyers, I wanted to get feedback on a comparison of the options provided by Frey:
Cassette:
Which would be more ideal with a 44t-48t chainring; the SRAM EX1, the 11-42t(10 speed), or the 11-46t (11 speed)?
Brakes:
Magura MT5 Ne is seen as better from my research, but are also seen by some as difficult to maintain; are the Tektro HD E725's poor or just average? And for a guy 250+ is the Magura a must?
DERAILLEUR
Shimano M6000 vs M8000?
GEAR SHIFTER
Fork (for commuting primarily)
Rockshox RECON Yari vs GTMRK
Battery:
48V/21ah (range) vs 52V/17ah (Speed)
Does anyone know a percentage difference between the two, ie how much more range is the 48v vs how much speed increase on the 52v?
Tires (commuting):
Supermoto X
2.4 vs 2.8? Which is more ideal?
If more offroading, go with the Rekon+
Gearsensor?
Ive read this is a no, as it can often go bad and cause a motor cutout at the wrong times?
Rear rack Y
Fenders Y
Integrated lights Y - Though these will no longer work if you go with the Archon?
extra charger Y
extra charging pigtail Y (works well with the Luna 52V advanced charger)
extra derailleur hangers Y
programming cable Y/N? Depending upon your preferred config method
Other Options not from Frey:
Motor Configuration tool:
EggRider Display? Thoughts?
Manual configuration via programming cable?
Archon Upgrade via Watt Wagons? Do the integrated lights still not work via this option? Thoughts?
Is it one or the other in this regard, or both?
All input is welcome and anything else to consider?
Cassette:
Brakes:
DERAILLEUR
GEAR SHIFTER
Battery:
Tires (commuting):
Supermoto X
Gearsensor?
Rear rack Y
Fenders Y
extra charger Y
