Hello guys,
My CCX came from Juiced with a slightly warped front rotor, so after 1100 miles I finally got time to replace the front rotor with a Shimano rotor.
I also tried to install the Shimano E01S metallic pads into the front caliper and even though the shape of the pads is the same as the OEM Tektro A10.11
I can not make them fit. The pads/spring sandwich goes all the way in with a click, but the retaining pin is slightly skewed, just enough that it misses the second
hole by about 1mm. The original used pads click and fit just fine, so it does not seem to be me doing something wrong.
The only difference that I can see between the Tektro A10.11 pads and Shimano E01S pads is the thickness of the backing metal plate with is slightly thicker in Shimano.
Any ideas if this can be solved?
if not which pads would you recommend for a commuter with a lot of miles that would definitely fit in the Tektro caliper?
