Most ebikes use instant current to "guesstimate" the remaining charge. They don't keep a track of watt-hours of spent energy. You slow down and the gauge goes up. Don't know whether calibrating it at the beginning by charging 100% and discharging to 5% (or whenever BMS will shut down) - don't know if this will have any effect on guesstimation work of an average ebike display.
Yes, you must guard it against deep discharges - like 10% remaining charge - when in use.
But, when in storage, the word is that keeping it 100% full is worse than keeping it near empty. Justin the Grin says so
. Hopefully at some point technical (and not too complicated) write-ups will be published that explain this.
An underused relatively inexpensive “watt meter” can be plugged in occasionally to see how a battery is performing. Not as good as a battery test station like Grin’s but better info than displays or the 15cent battery level led.
Watt Meter Display Screen
Startup Screen
Each time power is applied to the watt meter (or the auxiliary power connector), the startup screen is briefly displayed. Then the Amp-hours, Watt-hours, Peak Amps, Minimum Volts, and Peak Watts parameters are all reset to zero.
Display Parameters
The display screen will continuously measure and display Amps, Volts and Watts. All other values are presented sequentially every second. In the lower left position of the display, data values are identified by their units (Ah, Wh, Ap, Vm, Wp).
Amps (Current) & Peak Amps (A, Ap)
Only current from source to load can be measured. Drawing current in reverse will cause damage to the meter. The Amps (A) value displayed shows the average current over the last screen refresh. The Peak Amps value (Ap) displays the maximum current drawn since the meter’s last startup. Spikes or peak amperage readings lasting a fraction of a second may also be captured.
Voltage & Minimum Volts (V, Vm)
The displayed Volts (V) value is the average voltage from the last screen refresh. The displayed Minimum Volts (Vm) value is the minimum voltage or “sag” measured on the source side, since the meter’s last startup.
Watt-hours (Energy) (Wh)
The displayed value is the total energy delivered in Watt-hours since the meter’s last startup. It is measured from the load side for the most accurate results.
Amp-hours (Charge) (Ah)
The displayed value is the total charge delivered in Amp-hours since the meter’s last startup. It is measured from the load side for the most accurate results.
Watts (Power) & Peak Watts (W, Wp)
The displayed Watts (W) value is the average Watts (Amps * Volts) from the last screen refresh. The displayed Peak Watts (Wp) value is the maximum watts measured since the meter’s last startup.
Cheapest and most expensive/reliable...there are some better Powerwerx clones. Be sure to read capabilities and review.
