Do you need a speed pedelec, then the Aventon Pace 500. If no, the Pace 350. The Rize seems much too heavy given you want light weight, the Pace 350 model is 46lb vs 64lb for the Rize Mini. All three have been reviewed by riders as being a bit on off, with the Aventon 500 controller programming pushing hard up to 12mph in PAS level 1 which is too fast, hopefully this can be reprogrammed by the shop. Try the 350, the reviews suggest it has a more reasonable take off. See https://electricbikereview.com/foru...-at-start-especially-when-also-turning.29946/
Hello MAPC, if I were to choose between the two, I’d go with the Level. For $200. more, you get a front suspension, fenders, rear rack and longer battery capacity. The only drawback would be the extra weight.
