Fat bike tyres
Heavylevy
Hi Guys
I'm after recommendations for the best place to get tyres for a 2018 rad rhino I'm still running the juggernauts and I'm after road tyres.
I'm in the UK
Thanks in advance
Ade
My old 16 Radrover came with 30 TPI juggernauts. Very stiff tire that needed tools to take on/off, very flat prone, noisy, not very stable on turns at top speed because of the spaced out knobs, and the rears wore out in about 1000 miles.
I switched to Vee8 120 TPI 26X4 and like the softer tires a lot better. Very easy to put on/off, more flat resistant, less road noise, long tread life of 3X-4X of the juggernauts, and very stable at high speeds. The only issues I've had with these tires was "self steer" if PSI was below 15 PSI and needing 5 velcro straps to secure the almost flimsy tire on the rim to seat before airing up. It was almost impossible for me to seat a 120 tpi tire with a hand pump and no velcro straps (found out the hard way on a single track trail +5 miles from home). Unfortunately, these tires aren't being made any more and I found the last 4 on ebay a few years ago to save for a rainy day.
I would check out 120 TPI road tires compared to 30-60 TPI. I kept the inner tubes instead of going tubeless with the Vee8 tires because I've had quite a few flats too large for tire sealant to fix.
