I found this Evelo site lacking in information about their bikes provided by current owners. Thought I would offer my comments as I learn more about my Orion bike. So far about 160 miles logged. No real problems to note other than a couple of minor issues. Here are a couple of my first observations.
1. Evelo suggests having your new bike checked out by a local dealer. Good idea as I found that the front wheel bearing needed grease and several spokes were lose.
2. The Orion has a large frame and I found that at 5'-8" tall, I was leaning over way too far. Modified the raiser, stem and seat attachment to shorten the reach to the handlebars. Works fine now but would be marginal for someone shorter than 5'-8". I understand that a smaller frame model will be available sometime next year which should help shorter riders.
3. The Velo seat that comes with the bike is very comfortable.
4. The battery must be unplugged from the bike for charging.
5. I got 45 mileson a single charge using almost exclusively PAS 1. That level gives me about 10-11 mph.
6. Compared to my Trex 7100, the bike rides a little hard. Might consider a spring loaded seat support.
7. The wheel diameter should be set to 28" on the display unit rather than the 700 which is the actual tire size. The manufacturer of the display confirms this setting.
Will see how I do with using only PAS for the next charge.
