Envo tire problems?
Blork
Hello. I'm about to take possession of an Envo ST50. Really looking forward to it, as it hits all the right spots on my requirements list. But I did see some people in another forum (FB) commenting that they get a lot of flat tires with their D and ST bikes. It wasn't clear if this is a genuine problem or just a handful of people with a recurring problem. Someone from Envo came in and said there was a small batch of D35s that had a production problem that caused some flats but that was fixed long ago, but then one or two other people said the problem was caused by bad tires and crappy inner tubes.
So... has anyone here had any problems with flat tires on their Envo bikes? Specifically the D50 or ST50? Please let me know, and also if you found a permanent solution or if it's an on-going thing.
Thanks in advance!
IMHO,
The first thing I would do, when owning a new bike, regardless of the Brand name, is put FLAT OUT in the tubes/tires. This should stop most all leaks, unless you have a total blowout of the tires.
Also carry a good electric bike pump/patch kit as a back up etc.
It might save you some headaches in the long run. ymmv.
