Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
If it was making noise when not braking it's definitely warped. If it was beyond adjustment... Then it was what it was.Thanks for the response! To my knowledge both the original 203-19 and the replacement 203-53 are 1.8. In fact I asked the Trek tech to measure the 53 with a caliper, just out of curiosity. The big difference is the design is beefier with much more support in the center. Probably heavier but I’m far from a weight monger! There were 3 different techs who adjusted that front brake with the 19 and it just always ended up making that raspy noise whether I was actually braking or not!
Kinda like using large diameter saw blades... The cheaper ones flex and you better slow the material feed if you want a straight cut.
