I would like to build a portable 1 to 2kW car electrical system around scooter components. Scooters have fast charging. The following picture illustrates my goal. Charge a battery from EV J1772 stations for use with camping appliances like water heater, conventional 110V outlets, radiant heaters, etc.....
The Vectrix charger has a cooling fan and heat sinks, as explained in the second video. That gives me pause.
I have a feeling that I cannot use J1772 as i would like. J1772 has its own protocol. I suspect there might not be generic batteries that can be charged from EV charging stations.
I wonder how difficult fast charging is to implement for eBikes? TQ has clearly implemented it. I am forming the impression that Specialized will be late with its fast charging implementation. Fast charging seems complex to implement and test.
Why do scooters charge using XLR plugs, rather than Mosenberger used on eBikes?
I know from audio, the XLR have balanced inputs, they are grounded differently from conventional line inputs. XLR can detect errors and filter out noise.
The more I investigate fast charging for eBikes, the less I like it.
DC fast charging is more complex in that it must evaluate the condition of the battery and apply a charge level that the battery can safely absorb. A cold battery must be charged slower than a warm one; the charge current must also be reduced when cells develop high internal resistance and when the balancing circuit can no longer compensate for cell mismatch. (See BU-410: Charging at High and Low Temperature)
DC Fast Charging is not designed to fill the battery completely but to allow the vehicle to reach the next charging station. Using Level 2 is the preferred routine for everyday charging.
Level 2: 7kW typical
Wall-mount; 230VAC, 30A two pole, charges a mid-sized EV in 4 to 5 hours. This is the most common home and public charging station for EVs. It produces about 7kW to feed the 6.6kW on-board EV charger. The cost to install a Level 2 EVSE is about $750 in materials and labor. Households with a 100A service should charge the EV after cooking and clothes-drying to prevent exceeding the allotted household power.
EV driving range per minute charge: 670m (2,200 feet)
