Calcoaster
- USA
I have a garmin 130 plus and I run mission control on rides to collect data. I use the specialized “Ride” app after rides to see the data mission control logs. I like it because it gives graphs of battery charge, motor power, rider power that you can see at any point in the ride, plus a chart of time in each assist mode.
Now for the problem: I added an ebike field data field on my garmin that showed battery level and assist level. That worked fine but my Ride app no longer shows the battery level or time in assist modes. Mission control still shows the battery level. I want things back the way they were so I unpaired ebike field and removed it from garmin connect. That didn’t solve the issue. I went for a ride with the garmin turned off but Ride still doesn’t show the battery and assist level data that it did before using ebike field.
Any ideas about what else I can try?
