I have a custom e-bike, made by a bike shop in the city I live. It is a rear hub drive motor, class 2 with throttle, and has a vertically standing battery that sits behind the down tubing that holds the seat post. The controller sits in a box below the battery, with a face plate with 4 screws. The bike is about 9-10 months old, and after about 6 months or so I started to get intermittent problems where I would lose all power, usually when I went over a decent bump, but I could usually get it back by hitting the power button to turn it off, then hit it again to turn it on and power would come back on. This went on for about 3 months or so, then it finally stopped working altogether. And when I lost all power, the power light would go off.
So, I took it in to the shop, they found the wires had burned out, not sure where, but they fixed it, and I picked it up and on the way home, when I was riding it, the same intermittent problem started happening again, and could usually power off/on to get it back working, but just before I got home, It stopped and I could not get it back. I tried opening the controller box to check to see if I could find any loose connections, but found nothing. The bike sat for a week, as I had to wait for the weekend to take it into the shop again.
When I started riding it back to the shop, no power, then after about 20 minutes, I got power again, then after about 15 min more it stopped again. And all the while I was riding back to the shop that day, it was raining. So, dropped it off at the shop again, and they found the controller had gotten wet, so had to replace the controller. They thought the problem was the controller, but I don’t think that was the original problem, since I had the intermittent problem before it got wet.
But, the bike was now working, so I started to try it out and ride it around. At first it worked fine, but after about 5-10 min, then would stop, not even from any bump, and power off/on and it would start again. But, it was a little different this time, as when it stopped working the power light, remained on, but just the throttle did not do anything. The previous times, the power light would go off. So, I brought it right back to the shop and left it there again. They think it may be the throttle or wiring from the throttle.
I have a couple of questions:
- Any ideas what this intermittent problem is? Seems different the second time vs the first time though. First time, happened from a bump and the power light would go out. Second time, the power light was still on, but the throttle did not work, and it was not from any bump, but just in the throttling stop and go. And this second time, not sure if it would eventually almost totally go out. So, seems to be the throttle or wiring to the throttle this time. And first time was bump induced, so likely a wire connection, I am thinking.
- Do other people have problems riding their E-bikes in the rain? I will try to avoid riding in too much rain, but sometime still want to ride in a light sprinkle, or take the risk when it looks like a light rain. So, thinking that when I get the ebike fixed, then I can just either seal the controller face plate with some silicon gel, or maybe put duct tape around the box and plate that holds the controller. Wonder if other people had issues with riding their ebikes in the rain? Thanks for any response!
