In looking for a new bike I ran across the Charger and then started looking at the Nevo as well. What exactly are the difference between these two? Is it pretty much just the frame or are there other notable differences to consider as well? One of the big points is that they both have the same max weight rating, I'm on the heavier side and would like to use it for grocery running meaning I'd also want ~20KG overhead. Does the Charger's triangular frame make a significant difference in rigidity compared to the Nevo or is the Nevo's frame so overbuilt to make it pretty equal in practice?
