Low quality? I found out that a 7-speed derailleur requires three shifts to make the same difference as one shift on a 3 speed Sturmey Archer hub transmission, and each derailleur shift wanted a moment of easy pedaling. Letting up three times in a row when I came to a hill could bring me to a stop.
That's normal for a derailleur. I read that anticipation is the key to good shifting. With the Shimano Tourney, I was supposed to read the gear number through a distorted plastic window. I couldn't do that underway, and if I didn't know what gear was in, I couldn't anticipate the need to shift.
I bought another shifter, then found that the OEM shifter couldn't be detached from the cable. I had to throw away the cable that came with the new shifter and order an unusually long one, which was not readily available and cost more than the shifter.
Darn! I should have used a camera stand for that low-light, no-flash photo. It's too blurry to show that I used the laser to line up the sprocket tips of the wheels, not the chain. I think that takes the trial-and-error out of adjustment. (Besides a camera stand, I should have fetched a mirror. When I leaned in to be sure the light was on the tips, I had to be careful not to block the light.)
I first used the laser on a Radmission in 2022. It doesn't have a center stand, so I inverted it and leveled the bars by shimming. It's a single-speed, but I aligned the tensioner wheel with the sprocket wheel for the quietest possible pedaling.
