They won't wake up if you leave the switch on and the voltage drops below the BMS low set point.How do you know its dead? Did you put a voltmeter on it? If so what was the reading and what is the battery rating? (i.e. 48v 15ah) Did you check the output of the charger you are using to see if it works? These batteries usually have a BMS that puts the battery to sleep if not in use for a period of time. They wake up when you put a good charger on them.
It’s not the charger, you have to bypass the BMS to charge it. I know what to do, I don’t have the equipment to do it. That’s why I’m looking for someone to help meThey won't wake up if you leave the switch on and the voltage drops below the BMS low set point.
Again, the question is - what is the battery voltage? Has battery been discharged so deeply that nothing happens when you connect the charger?It’s not the charger, you have to bypass the BMS to charge it. I know what to do, I don’t have the equipment to do it. That’s why I’m looking for someone to help me
It's likely that nothing failed. The battery pack probably had a drain on it and it went below the safety point set on the BMS. Guessing and logic will never replace engineering and science. Your suggestion could cause even further damage to the pack and possibly a fire. Be careful what you offer to the world.I really don't know anything about this but logic dictates a pack can't fail, it's made of individual cells, some can fail but not all at once even drained.
BMS issue i would guess, bypass it, that may take tearing the pack apart to get voltage directly to the cells.
