Cyrusher 650 Throttle replacement
iceclimber
Hi, likely a new guy question but what is the type of throttle specification is needed to replace the 650's half twist? I thought if I bought a compatible plug (3 prong male) it would work but nope.
The bike display even threw "ERR" to help me out when I plugged in the new one.
Thanks !
I'm looking for a replacement too. I've bought 2 different ones from Amazon with no luck. I've sent an inquiry to Cyrusher. I'll post what I find out.
I bought a Cyrusher XF650 Electric Bike and it came with a Thumb throttle, I found out after testing the wiring that the throttles that Cyrusher supply are wired differently this is probably so people pay the 69 bucks or pounds depending where you are in the world I got mine from the UK. To get throttles from amazon to work all you need to do is to cut the throttle cable and solder and heat shrink the cable back together. The wires from the bike are (White = +5v , Black = -5v and Red = Speed Signal) so on the throttle side connect (Throttle Red to Bike Side White), (Throttle Black to Bike Side Black), and (Throttle White to Bike Side Red) This works perfectly so any cheap throttle can work on a Cyrusher Electric Bike. Dont get wasting money for rip off throttles from Cyrusher
