ezrider101
- Europe
Hello
As my first post, I would like to ask a technical question.
I decided to order NCTE torque sensor (same as is used in Brompton) which also has cadence sensor in it because it can be used with belt drive and my crankset.
Therefore I will need custom made controller for it and the problem is the factory does not know what settings to use for the torque sensor/cadence sensor part so that it will work properly.
Am I wrong or, will the solution be just to copy this diagram from the torque/cadence sensor's factory instructions in above diagram to the settings of the controller (the text in red) and it should work ok? Any advice would be most appreciated as I get only one shot at this custom controller which is expensive to arrange.
Thank you in advance for any advice.
