Captain Slow
The GRX 800 Series is supposed to be comparable to Ultegra. I think the E5 Creo has a mix of 800 and 600 level GRX components, so I would guess it's a mix of Ultegra and 105.
My regular road bike is a Trek and I love it...but I ride a 47 frame and the new Domane doesn't come in that size :-(Trek Domane + HP ? 1kw battery and is removable. Much faster and powerfull then the Creo. Bosch gen. 4
Creo SL Comp Carbon is not Ultegra, it's GRX. Did you upgrade?<snip> but was perfectly happy with Ultegra on the Creo Comp. There is only one chainring after all. <snip>
disappointed with the bike's power on the hills.
Thank you for sharing your experiences. How steep is the hill (% grade), elevation difference, and how long is it? Finally, did you use the default preset in Mission Control?<snip>
What surprised me the most about the two bikes is the difference in power on a very steep hill I went up.
If I had ridden up this hill on my carbon road bike I would have had to stand up in the saddle. With the Aluminum Creo I didn't have to get out of the saddle, but it was far from an easy ride. I knew I had climbed a hill when I got to the top.
When I tackled the same hill with the Creo carbon it felt like the motor had a bit more power. Since the motors are the same I suspect the felt difference was due to the 3 or 4 pound weight difference between the two bikes.
The weight difference definitely made a difference on the steep hill, but wasn't as noticeable on the hills with less of an incline.
Honestly, I was a bit disappointed with the bike's power on the hills. I guess I was expecting more "oomph", especially the really steep hills. I understand why Specialized went the way they did, but I wish it had a bit more power.
<snip>
No I misspoke in my earlier post. I got the standard build. I do find the shifting to be fine though.
Maybe the Creo SL is not ideal for you if you want more assistance, it was designed that way. The marketing of "It's you, only faster" works for me. A rider still need to put out power, and that's why I love it and has become my exercise machine. I regularly (once a week) climb a route with 28.8% grade and I'm on Sport mode only for that section of about 2km (80% on Eco), no need for Turbo for all routes I've done since buying the Comp EVO.I was down to the lowest or second from the lowest gear and on full power (level 3). I guess I was surprised at how much energy I had to put out to get up the hill. I thought the motor would give me more of an electrical boost.
The motor was in the default preset and the climb was only about 100 meters in length.
For a comparison I need to ride the same route with my 18 pound Giant Defy Advanced Pro 0.
I guess I should also mention that a couple of days ago I took out another ebike for a test ride. This one had a peak power of 1600 Watts.
You're probably right. After riding the Creo I think I'd be happier with something like the Bulls Desert Falcon EVO. Unfortunately, it's not available in Canada.
18.82 kg but Di2How much does that bike weigh though?
True for the Vado although the Vado also likes higher cadence better.Unlike my Vado which has lots of low end grunt
Another thing to remember is the Creo REQUIRES 70rpm cadence to produce full power. Lower cadence greatly reduces power. Unlike my Vado which has lots of low end grunt
On a Creo test ride I noticed that if you let the cadence drop to 60 or even 50 on a climb, you loose ground FAST. I usually ride around 70 on flats and often drop to 60 on climbs. I need to modify this behaviour when I get my Creo.
