Creo motor bolt, chain ring torque
Calcoaster
I just got a chain guide from Specialized and want to double check the torque specs before I put it on. It comes with a bolt that replaces a motor mounting bolt and has internal threads for a small bolt that holds the chain guide arm.
The Specialized doc I found online is titled “S-Works Creo SL User’s Manual”. I have the carbon comp. I assume the motor mount bolts use the same torque since the frame is the same, but I’m not sure of the chainring torque since the 2021 S-Works used a SRAM ring vs the Praxis I have.
The document calls for Drive Side Motor mounts 17 NM, non drive 10 NM, and Chainring bolts 10 NM.
Anyone have any different information?
Thanks!
