Can't disable PAS and operate throttle only ?????
ChrisKatouzi
I don't understand: in our advanced menu, in "P10", we have the option of setting it to either 0,1, and 2 as you see below.
But the default is 2: both PAS and Throttle are active. And you cant change it.
If you set P10 to either 0 or 1, it will stay on 2 PAS and Throttle are active
Why can't we change it?
But here is where it gets interesting. I once accidently changed one of the settings that we are not supposed to touch (I think it was P26 - and you're only supposed to change P01,02,04,06,09,10,11,12,16, and17). So my speedometer and PAS stopped working. Customer service immediately fixed the problem by sending me a complete list of the proper settings, but for a while, I had PAS inactive and Throttle Active. and now it's what i want
Don't you thnk that should be an option to control your own trust and turn off PAS? I'm actually going to my notes looking for the wrong setting code that i had. .. It should be something we switch on and off.
