AHicks
- USA
- City
- Snow Bird - Summer S.E. Michigan, Winter Gulf Coast North Central Fl.
What happens when you tighten the shift cable, even pulling on it with your fingers back by the derailleur? You SHOULD see the derailleur move toward the next smaller gear (8th)......My 2020 Sport will not shift from 7th to 8th gear. I have watched the videos and adjusted the limit screws and adjusted the barrel adjusters for tension. Any other ideas before I strap sporty on the rack and take him to the LBS?
The derailleur doesn't appear to be bent...
If it's not moving towards 8th when shortened/pulling on it, you'll need to figure out why - like a limit screw miss adjustment for instance......
