its out and I got one but it seems hard to get. before you buy it what are you after? it is an expensive upgrade and the ebike connect software does not really connect to anything but the kiox.when will bosch nyon 2021 retrofit kit be available to purchase
on bosch website it states that it was released already but i dont see it an any stores to purchase it
thanks
any upgrade requires a motor drop and new cables run. so besides the cost of the kiox you have to pay for the work too. took two hours on my bike the wire was so hard to get inserted they had to tear the whole front of my bike apart. my shop found it from a supplier but that was over a month ago.i thought it was just an easy exchange between kiox and new nyon
i like the fact that the screen is bigger and the maps are on it
where did you buy it from
I meant the ebike connect app does nto connect to anything on your phone like strava or health that's what I meant.[
@fooferdoggie -The Nyon does indeed sync to the eBike Connect app
@misteracng -- you're in luck. The Smartphone Hub shares the same wiring as the Nyon. This should** be able to be upgraded at the handlebar area by removing the wires from the hub and installing them to the Nyon. Always exceptions in terms of frame design. A software update will be needed through your Bosch dealer.
@BoHappy ---the Nyon has been released. It is appearing on some OEM models coming into shops at this time. We are awaiting retrofit kits to be available through our US service partner. That should occur around October.
thank you for your response Stephen
is it also true that the wires don't need to be rewired to change kiox to nyon - and just the holder needs changing?
excellent news, thanks@BoHappy ---the Nyon has been released. It is appearing on some OEM models coming into shops at this time. We are awaiting retrofit kits to be available through our US service partner. That should occur around October.
when I replied to this for some reason I thought he was asking about the kiox. but you said the Nyon would let you adjust assist levels? like the percentage they help? m=right now tour is too much be eco is not quite enough for me to keep at about 22mph.Correct. This should be the case if the wires are long enough for your cockpit and frame design.
Not a new feature but a Nyon only feature.when I replied to this for some reason I thought he was asking about the kiox. but you said the Nyon would let you adjust assist levels? like the percentage they help? m=right now tour is too much be eco is not quite enough for me to keep at about 22mph.
Hi Stephen, Is there any possibility there will be an adapter that will fit the Kiox Base and mate with the Nyon retrofit display. Not sure if the number of conductors required for both might be the same so just a thought. I may be that your reference to software upgrade required might mean not just a simple changeover if an adapter was available.@BoHappy ---the Nyon has been released. It is appearing on some OEM models coming into shops at this time. We are awaiting retrofit kits to be available through our US service partner. That should occur around October.
The wiring is the same, but you do need to swap the mount. It’s not a big job though.Hi Stephen, Is there any possibility there will be an adapter that will fit the Kiox Base and mate with the Nyon retrofit display. Not sure if the number of conductors required for both might be the same so just a thought. I may be that your reference to software upgrade required might mean not just a simple changeover if an adapter was available.
Thanks Stephen from downunder.
thanks for the heads up ChrisThe wiring is the same, but you do need to swap the mount. It’s not a big job though.
just to be clear. For those of you in North America the Nyon won’t be available as a retrofit until early next year. I know many have been confused by this thread.
I’m not sure but it’s likely. The trouble is that Bosch USA might not offer a warranty for a product from Europe as it is slightly different. The US product is UL listed where the EU product isn’t.thanks for the heads up Chris
just a question i have a friend who is coming from Germany - will this kit be available there earlier than here
would it be the same if i have him bring it to me as the one thats for USA market
The Smartphone Hub has been available. I know it was slightly delayed, but it is available now. I’m pretty sure we have stock at our stores.I remember hearing last year the smartphone hub would be out by feb. nope I am not sure it is out even yet.
I was not sure but it was way delayed.I’m not sure but it’s likely. The trouble is that Bosch USA might not offer a warranty for a product from Europe as it is slightly different. The US product is UL listed where the EU product isn’t.
