harryS
Something I tried just for fun was a DC boost converter. These are used to boost a DC voltage to a higher number, a very common application, but I wasn't sure it would work with a cheap converter and the demands of an ebike. Other users say it works, so I was willing to chuck out $23 on ebay for one of these 1500W 30A dc-dc converters.
It's is cheap. My vendor threw it in a plastic bag and sent it without any packing. It arrived bent up and with a capacitor broken off. If it had been amazon, I would have made him take it back, but it's a guy in China. I soldered a new capacitor on it and it worked, so I took a 25% discount. There's a fan on the bottom, but it doesn't work yet.
Here it is when I tested it on a 36V pack. It can put out up to 90V, but I didn't go above 60V. It's rated for only 20 amps output, so it cannot do miracles.
I tried it in my fat bike with a 25A controller, putting out 58V from a 36V pack, and it would shut off any time I gave it throttle. No miracles. With a max of 20A available, no good for big bikes.
I tried it with a 20A controller in my 36V 250W folding bike, this time with 50V from a 36V pack. It gave a nice kick in performance. The watts in assist level 1 went up 20%. Top speed went from 19 to 24 mph, Both of these compare to when I put a real 48V battery on that bike.
Since this is the Ecotric forum, I put it on my Ecotric 20" fat tire folder also with a 20A controller. I use the stock 36V silverfish battery on that bike. I set the output to 50V. Worked nice. The bike did not shut off or get starved for current. Top speed of about 25 mph indicated, compared with 20mph before. I rode around for an hour without incident.
One thing I noticed. The Ecotric 36V battery would sag about 6-7 volts under throttle. I have a voltmeter on my handlebars and can watch that. With the boost converter installed, the bike voltage only dropped from 50 to 49 volts, while the battery voltage still drooped 6 volts. The converter is able to maintain the voltage, but the cost is it sucked 30A out of the battery to do this. This means that as the battery discharges, the bike won't lose performance from lower voltage. However the battery will discharge faster because it has to make up that power in the converter,
So I was pleasantly surprised. It's not a free lunch since it uses more power. You do have to set the converter so it shuts down at the proper minimum voltage for your battery. I haven't tested to see if this works.
I might use it on another ebike project to run a 48V motor on a 36V battery. . It's too unwieldy to install on my Ecotric. Wires all over the place.
